How can I get the linker settings
Jinhuan
Post by Jinhuan » 28 Sep 2016, 08:38
I searched in the internet from project->properties->configuration properties->linker,but I can't find the linker. who can help me? thank you!
Jinhuan
Re: How can I get the linker settings
Post by Jinhuan » 28 Sep 2016, 08:46
As I met the error below:
Error 12 error LNK1112: module machine type 'x64' conflicts with target machine type 'X86' D:\BCI\BCI2000 source\build\CMakeFiles\buildutils\create_resource.dir\RelWithDebInfo\create_resource.obj 1 1 create_resource
If anyboby can help me or give me some advice, thank you,I'm waiting online.
Post by pbrunner » 28 Sep 2016, 10:44
Jinhuan,
this error message is because of an inconsistency in your temporary build files. I assume that you have initially build a 32-bit version and have now changed to 64-bit. To resolve this, you can try to select "Clean All" before "Build All", or alternatively, delete the build directory, update the working copy of SVN to restore the build directory, create a new visual studio solution file and build again.
Jinhuan
Post by Jinhuan » 29 Sep 2016, 07:54
Hi peter,
Yes, you get the point, and it worked after done what you say, thank you very much!
Joyce jin
Users browsing this forum: No registered users and 6 guests
