P3Speller error
ariel
P3Speller error
Post by ariel » 17 Mar 2009, 13:06
During the execution of our application errors occur at random in the module P3Speller.exe, jumping posters as:
P3Speller.exe error "Assertion failed: TP2, xxtype.cpp file line 262"
P3Speller.exe error "Assetion failed: topTypPtr! = 0 & & IS_STRUC(topTypPtr-> tpMask), file xxtype.cpp, line 847"
What is the problem?
Ariel
P3Speller error
Post by gschalk » 17 Mar 2009, 22:28
Ariel,
Does this error occur with the most recent version of BCI2000? Are you using any custom components? Which modules are you using? Assuming you use the standard BCI2000 components, can you also post a parameter file?
Users browsing this forum: Google [Bot] and 1 guest
