probelms about data
john
probelms about data
Post by john » 02 Jun 2015, 23:55
Greetings all
Does every .dat file can be analyzed by BCI2000 without relying on the experimental data of BCI2000 directly?If it is possible, how can it be done?
Thank you
Re: probelms about data
Post by pbrunner » 03 Jun 2015, 10:51
John,
I am not sure if I exactly understand your question, but you can analyze the BCI2000 data after the fact in MATALB. For this please use the load_bcidat mex function that is provided with BCI2000 [1]. In addition, you can replay data through BCI2000 [2].
[1] http://www.bci2000.org/wiki/index.php/U ... oad_bcidat
[2] http://www.bci2000.org/wiki/index.php/C ... lePlayback
