Problem with configuring
bnorris391
Post by bnorris391 » 29 May 2015, 11:14
Greetings all -
Brand new to BCI2000. Downloaded the software and was trying to get through the tutorial. Loaded parameters according to the instructions. When I click Set Config, I get the following error:
DataIOFilter::Preflight: BCI2000FileWriter::Preflight: Cannot write to file C:\Program Files\BCI2000\prog\..\data\test001\testS001R01.dat.
I've tried changing the Data Directory, but no success. Any assistance would be greatly appreciated.
Thank you,
Brad Norris
Re: Problem with configuring
Post by pbrunner » 01 Jun 2015, 10:41
Brad,
can you please try to install or copy the BCI2000 folder to C:\BCI2000 and then report back whether running BCI2000 from there resolves the issue?
bnorris391
Post by bnorris391 » 04 Jun 2015, 14:23
That solved it! Thank you very much. I am grateful for your assistance.
Brad
