Compling custom module on OSX
Posted: 12 Jul 2013, 13:47
Note, I was able to compile on my Windows machine. I don't need to use my mac but I was hoping to use it as an at-home development machine. It's not urgent. I'm only just learning C++ but maybe I can help get BCI2000 working on macs.
First, a CMake error.
Using OSX 10.7 and CMake 2.8.11.2 and the BCI2000 source code updated from SVN just now (Revision: 4522).
Sorry, I'm not good enough with CMake to fix this in the CMake files.
If I use cmake-gui and uncheck the BUILD_TOOLS option then I can configure and generate successfully for either XCode or Unix Makefiles.
I then followed the quick start guide http://www.bci2000.org/wiki/index.php/P ... tart_Guide . worked as expected.
I used those tools to create ../src/custom/EEGfMRISignalProcessing and one of its filters GradArtRemoval
I then removed the intentional errors from PipeDefinition.cpp and GradArtRemoval.cpp
I then redid CMake's Build and Generate.
Then I tried to build this module and I get the following error:
So I edited those lines in /src/shared/types/ValueList.h replacing size() and empty() with this->size() and this->empty(). Then I got a little further in the compile.
There was a common error that 'foo' is not a member of 'std'. This is because both Xcode and the gcc that come with OSX default to using an older version of the standard library. One option is to simply add to src/shared/bcistream/BCIException.h . However, this is not the only std-related error so the better option is probably to tell your compiler to use the new library.
If using Xcode, click on the BCI2000 project, then in the Build Settings scroll down to Apple LLVM compiler - Language. In that section change C++ Language Dialect to C++11 and change C++ Standard Library to libc++.
That gets me further but I'm then confronted with errors I don't understand.
If not using Xcode, but using Clang, first you'll have to download the Xcode command line tools from the Xcode>Preferences>Downloads window. You'll also have to add the following to BCI2000/build/CMakeLists.txt
Eventually this gives me the same error as using Xcode.
If not using Xcode and using gcc, first get the latest gcc following these instructions [link]http://www.ficksworkshop.com/blog/14-co ... gcc-on-mac[/link].
For all versions of gcc I tried, I could not set the CMAKE_CXX_FLAGS -stdlin=libc++ (the other flags worked). I think that flag is not necessary with gcc, however, I once again had to edit BCIException.h as above.
Once I did that, the compile went a little further but stopped at
I need a break.
If anyone out there has compiled modules successfully in OSX then please tell me which compiler you used and if you used any special compiler flags.
-Chad
-- Target #32: BCI2000Viewer (Tool, QTAPP)
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/BCI2000ExportQt/moc_MainWindow.cxx.rule" which already has a custom rule.
-- Target #33: BCI2000Export (Tool, QTAPP)
-- Target #34: BCI2000Launcher (Tool, QTAPP)
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/P300Classifier/moc_configdialog.cxx.rule" which already has a custom rule.
CMake Error: Attempt to add a custom rule to output "/Users/cboulay/Documents/bci2000/build/CMakeFiles/core/Tools/P300Classifier/moc_pages.cxx.rule" which already has a custom rule.
make NewBCI2000Module NewBCI2000Filter NewBCI2000FilterTool
Chadwicks-MacBook-Air:build cboulay$ pwd
Chadwicks-MacBook-Air:build cboulay$ make EEGfMRISignalProcessing
[ 0%] Building CXX object CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp.o
In file included from /Users/cboulay/Documents/bci2000/src/shared/types/SignalProperties.h:33,
from /Users/cboulay/Documents/bci2000/src/shared/utils/MeasurementUnits.h:30,
from /Users/cboulay/Documents/bci2000/src/shared/accessors/ParamRef.h:36,
from /Users/cboulay/Documents/bci2000/src/shared/accessors/Environment.h:41,
from /Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.h:34,
from /Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp:29:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h: In member function ‘int ValueList<T>::Size() const’:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:37: error: there are no arguments to ‘size’ that depend on a template parameter, so a declaration of ‘size’ must be available
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:37: error: (if you use ‘-fpermissive’, G++ will accept your code, but allowing the use of an undeclared name is deprecated)
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h: In member function ‘bool ValueList<T>::Empty() const’:
/Users/cboulay/Documents/bci2000/src/shared/types/ValueList.h:38: error: there are no arguments to ‘empty’ that depend on a template parameter, so a declaration of ‘empty’ must be available
make[3]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/filters/GenericFilter.cpp.o] Error 1
make[2]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/all] Error 2
make[1]: *** [CMakeFiles/custom/EEGfMRISignalProcessing/CMakeFiles/EEGfMRISignalProcessing.dir/rule] Error 2
make: *** [EEGfMRISignalProcessing] Error 2
#include <stdexcept>
/Users/cboulay/Documents/bci2000/src/shared/utils/SockStream.h:262:38: No member named 'operator void *' in 'std::__1::basic_iostream<char>'
/Users/cboulay/Documents/bci2000/src/shared/utils/Lockable.h:91:7: Non-const lvalue reference to type 'std::ostream' (aka 'basic_ostream<char>') cannot bind to a temporary of type 'std::__1::basic_ostringstream<char, std::__1::char_traits<char>, std::__1::allocator<char> >'
if(APPLE)
set (CMAKE_CXX_FLAGS "-std=c++0x -stdlib=libc++ -g3 -Wall -O0")
endif()
[ 19%] Building CXX object CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp.o
/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp: In function 'void ThreadUtils::Yield()':
/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp:132:3: error: '::pthread_yield' has not been declared
make[3]: *** [CMakeFiles/frameworks/CoreLib/CMakeFiles/BCI2000FrameworkCore.dir/Users/cboulay/Documents/bci2000/src/shared/utils/ThreadUtils.cpp.o] Error 1
-Chad
