Hello everyone
I'm new to this software and I already have some problems.
I tried to open the P300Classifier.exe file but it shows an error message:
"This application failed to start because no Qt platform plugin could be initialized."
I tried to reinstall the software, and I even tried it from two different sites, but nothing happens
http://bci2000.org/downloads/bin/BCI200 ... .setup.exe
How can I solve this so I can use P300Classifier?
Thanks!
PC300Classifier does not open
- Error shown
- Captura.JPG (19.37 KiB) Viewed 109 times
Re: PC300Classifier does not open
This is due to an error in P300Speller that was fixed in r6166.
I'm sorry that you experienced this issue.
We generally recommend to build BCI2000 from the latest SVN version as described here:
If you would like to fix your version of BCI2000, you can go to the P300Speller directory, and move the "platforms" plugins directory out of the "qtplugins" directory into the "P300Speller" directory, such that "platforms" is a direct child of "P300Speller".
Note that this will not work with the "bundled" versions of BCI2000, as the plugins are located inside the bundle and cannot be moved.
Regards
Jürgen
Regards
Jürgen
Thank you, very much, Jürgen
That worked and now I can open the P3000Classifier.
Eduardo
Eduardo
