my own program
myr
my own program
Post by myr » 14 Jul 2009, 04:17
I have written my own program (a pong game) to interface with the bci software via the udp app connector method (http://www.bci2000.org/wiki/index.php/T ... _Connector).
It works fine, everything is happy there - however my users hit a couple problems when they attempt longer sessions, as the default limits of mufeedback are around 3minutes of tests - is there a way to either extend the built in session limit, or another application that gives the output, but doesnt limit the duration?
feedback ...
Post by gschalk » 14 Jul 2009, 09:48
Several parameters control the timing of operation of the CursorTask (which I assume is what you are using). This includes the maximum duration of a run. Please check out
http://www.bci2000.org/wiki/index.php/U ... CursorTask
for a listing of those parameters.
