Using BCI2000 with Unicorn BCI
GiuseppeG
Post by GiuseppeG » 26 Sep 2019, 05:57
Hi!
I am trying to set up a P300 session on BCI2000 with the Unicorn BCI.
I have tried to stream the Unicorn data through an LSL stream but the LSL source module of BCI2000 seems does not recognize the LSL stream.
So I would ask if there is a particular developed module to interface the Unicorn BCI to BCI2000, or there is a particular way to let BCI2000 recognize the LSL stream.
Thank you.
madamek
Re: Using BCI2000 with Unicorn BCI
Post by madamek » 08 Oct 2019, 13:29
Instead of using LSL, you might want to try the BCI 2000 Unicorn module.
BCI2000 Wiki link: https://www.bci2000.org/mediawiki/index ... UnicornADC
It should be compiled by default and can be started via gUnicornADC with the batch file.
If you can't find it try to update your SVN and recompile BCI2000.
-Markus
