Hi I have sent messages through UDP but, I send parameters that are superfluous information,
making between readings of channel values have values of 0.
Is there any way to reduce the message sent to only send the value of the channels?
Thanks!
Information's sending
Re: Information's sending
Paico,
you can use the "ADD WATCH" command in the AppConnector scripting to specify the variable that are transmitted:
Users browsing this forum: No registered users and 12 guests
