Using BCI2000 with Emotiv
hercp
Post by hercp » 08 May 2014, 21:04
I have installed BCI200contrib.exe. I would like to use BCI2000 with Emotiv. When I try to ru Emotiv.exe from the Prog folder, I get an error: "SignalSource could not connect to the operator module". Is there a step I am missing?
Heracles Panagiotides
Re: Using BCI2000 with Emotiv
Post by boulay » 11 May 2014, 21:36
You can't run a BCI2000 application module on its own. You need to start with Operator, and you'll also need a signal source module and a signal processign module. Try starting with a batch file (found in BCI2000\batch) or try using BCI2000\prog\BCI2000Launcher.exe
-Chad
