Hello everyone,
I ran into problems implementing a CSP filter when I realized that none of the covariance matrices estimated from my data were positive definite (i.e., alwyas one negative eigenvalue). I estimate the covariance R in one trial by
R = (X X')/ trace(X X')
and then average across trials (as recommended here)
As I am a newbie to EEG, I wonder about the most likely cause of this and how to address the problem.
- how many trials with how many data points do you normally need to estimate a covariance matrix? (can this be due to sparse data?)
- can this be due to insufficient artifact removal?
- is this a theoretical problem?
- a technical problem?
- is there a simple way to address this?
thanks a lot!
Marieke
[/url]
covariance matrix estimation
Large negative or small negative?
It's fairly common for EEG cov matrices to have fairly poor condition, and the last eigenvalue may even be 0 (+/- numerical-precision fuzz) if the EEG data have been expressed relative to a common-average reference or CAR (subtracting the mean-across-channels clearly reduces the channel dimensionality by 1 since one channel is now linearly predictable from the other n-1). Additional eigenvalues may be 0 if you have flat (dead) channels in there. Look at the raw data.
But really negative ? No, covariance matrices are by their nature at least positive-semidefinite for real-valued data. So you may have a flawed covariance estimator on your hands. Maybe check the sanity of R in some other ways: is it [number of channels x number of channels]? Is it symmetric? Is it real-valued? Are there Infs and NaNs anywhere?
Note that the formula you've given for R computes non-central covariance. Unless you already subtracted the mean (for example by high-pass- or band-pass-filtering each channel) which is standard practice for CSP and friends.
Finally, a few seconds of EEG should give you an R that is sane, if not especially robust. A few minutes should give you something fairly stable.
thanks, jhill,
I didn't realize that CAR means loosing one channel but it makes sense - so maybe i just chuck out the first eigenvector (that has a small negative eigen value < -0.01) out or maybe i do not apply the CAR in the first place. all the trouble probalby results from there then, because otherwise, it's all well-formed, the data is band-pass filtered and all channels give reasonable signals.
well thanks for this very useful advice - this will surely not be the last time i'll post questions wth obvious answers here
it should be stable enough, in that case (ca. 200x1s)a few seconds of EEG should give you an R that is sane, if not especially robust. A few minutes should give you something fairly stable.
Users browsing this forum: No registered users and 16 guests
