BCPy2000 timer
dhruv aggarwal
BCPy2000 timer
Post by dhruv aggarwal » 13 Jul 2011, 22:41
hi
I also wanted to know if there is any variable defining a timer during the run in BCPy2000. I need to use a timer which starts from 0 at the beginning of the run and continues until the run is suspended.
Kindly help.
Dhruv
Re: BCPy2000 timer
Post by mellinger » 02 Aug 2011, 10:36
the BCPy2000 Process hook is called once for each sample block acquired from the EEG system. To get a timer in units of sample blocks, define a variable and increase it by 1 from inside the Process hook.
To convert sample blocks into seconds, multiply by the SampleBlockSize parameter, and divide by the SamplingRate parameter.
