I cannot open the BCI2000 Viewer. When I click on it, my cursor circles for a bit and then goes back to normal, but nothing else happens. Is there anything I can do about this?
Thanks in advance!
BCI2000Viewer won't open
Re: BCI2000Viewer won't open
BCI2000Viewer works fine for me (x64 release build on 64 bit Windows 10).
Maybe deleting BCI2000Viewer.ini in the BCI2000Viewer directory can fix your issue.
Thank you for your response. I could not find BCI2000Viewer.ini. My BCI2000Viewer directory (C:\BCI2000.x64\tools\BCI2000Viewer) only contains a BCI2000Viewer.exe and BCI2000Viewer.html file. Is this incorrect?
Does the Operator module work if you double-click it?
Thank you for your reply, I managed to fix the issue by reinstalling Qt and configuring and building the BCI2000 source code from scratch.
Users browsing this forum: No registered users and 22 guests
