NeuroSky data analyze & artifacts delete
Murad
Post by Murad » 30 Jan 2017, 11:27
Hi, people. I have EEG studies by NeuroSky system. So, I have one question. Will be able using BCI2000 for my data analyze and artifact delete to offline? I sent mail in support center of NeuroSky and they answer me: "*.dat its stream file for store data by Hex format right? if its hex stream from our device you need parser it by following doc".
So, BCI2000 contains a module for data logging with NeuroSky devices.
http://www.bci2000.org/wiki/Contributions:NeuroSky
But, as I understand it, the module is just to read the data from the device online?
Can I view the recorded files already - is not clear.
May be I have to write a parser yourself. I'm no creating parser, because I'm physiologist, no programmer)
Can you prove of probabilities my file by BCI2000 device and will say by result? (.dat file under)
So, recommend somebody to do something?
Thank you in advance for your reply.
P.S. analysis pattern: https://cloud.mail.ru/public/HAra/qfvbzZLHN
