Data in each step of a Visuall P300 Speller
bertocasta
Post by bertocasta » 11 Jun 2015, 13:11
I'm trying to perform an analysis of a P300 Visual Speller and I need to get some figures of the data. I've acces to raw data (files .dat created by the BCI2000 application). As long as I know, the processing steps are as follow:
*Spatial Filter (CAR or others)
*Dividing in epochs and averaging
*Classifcation
I need to get the data after the CAR Filter and the epochs aswell. Is there any way to acomplish this?
Thank you.
Regards, Alberto.
Re: Data in each step of a Visuall P300 Speller
Post by pbrunner » 11 Jun 2015, 14:11
Alberto,
BCI2000 provides the Offline Analysis tool for this purpose [1]. Alternatively you can import the data into MATLAB using the load_bcidat mex interface [2], or into other programs using the ASCII files that the BCI2000Export tool creates [3].
[1] http://www.bci2000.org/wiki/index.php/U ... e_Analysis
[2] http://www.bci2000.org/wiki/index.php/U ... _MEX_Files
[3] http://www.bci2000.org/wiki/index.php/U ... 2000Export
bertocasta
Post by bertocasta » 11 Jun 2015, 14:35
Hi again, Peter,
I've tried to use all of these options.
[1] Offline Analysis only allows me to plot the r-squared value or target/non-target stimulus for a given channel and time interval.
[2] I've sucessfully loaded the XXXXXX.dat file. But at this point, no processing is done. I only have the raw data.
[3] Same as [2]
So what I pretend is to get the data after the CAR SpatialFilter but before epoching, after epoching but before classifying and after classifying.
Regards, Alberto.
Post by pbrunner » 11 Jun 2015, 14:43
Alberto,
try the BCI2000 P300 GUI that was bundled until v2.0 [1]. No guarantees that it will still work, but if you run that in MATLAB you have access to all intermediate steps.
[1] http://tinyurl.com/pokjwbr
