Running BCI Without Application Module
Yuliy
Post by Yuliy » 26 Jan 2011, 11:03
Is it possible to run BCI without an application module? Meaning the last module in the sequence. I only want what comes out of the AR Filter, I don't need a module (like CursorTask) to be running. If BCI needs a final module to run, it there a way to make a passive module? Meaning it doesn't do any commuting of its own.
Yuliy
Post by jawilson » 26 Jan 2011, 11:45
I have written a DummyApplication module, that does exactly what you need, i.e., there is no application display or other output. You can reply with your contact info, and I can send it to you.
Adam
Yuliy
Post by Yuliy » 26 Jan 2011, 12:03
That sounds great. You can e-mail me at tua88288@temple.edu
Yuliy
