how to build flashing parameters ?
elita
Post by elita » 15 Nov 2010, 17:15
hello
I'm working on processing signal, with signals that have been adquired with BCI2000.
Now I was going to use, a database of the UAM (Autonomous University of Mexico), but I noticed that they did not keep their data in the parameter of flashing, which I need to process it. It is possible to infer this parameter from others?. which could use?
Greetings.
Post by mellinger » 17 Nov 2010, 08:22
Elita,
are you referring to a BCI2000 state called "Flashing"? This state's information may be recovered from the "StimulusCode" state, by testing for StimulusCode != 0.
elita
Post by elita » 17 Nov 2010, 11:35
thankkkk'sss I didn't think in that solution
thank for the help
:D:D:D
Eli
