Can BCI2000 read raw eeg from emotiv epoc headset ($299)?
dvboy
Post by dvboy » 17 Aug 2010, 13:08
Post by jawilson » 30 Aug 2010, 10:25
Yes, Emotiv research headsets are supported as a contribution.
Emotiv
Post by gschalk » 30 Aug 2010, 16:29
The EPOC is supported, but you need the research edition ($700 or so). I do not think that the cheaper versions can stream EEG.
iicke
Re: Can BCI2000 read raw eeg from emotiv epoc headset ($299)
Post by iicke » 24 Dec 2010, 14:06
As you can see on Emotiv's forums, the consumer version is protected via encryption so you can't use raw EEG. You can buy the research version for $750 for that. I've heard that somebody actually hacked the consumer version but I believe Emotiv already counter-acted against it. So, Research version is the way to go if budget is not a problem.
dvboy wrote:Can BCI2000 read raw eeg from emotiv epoc headset ($299)?
