actichamp failed to get device handle
I am a starter to BCI research using BP's actichamp EEG amplifier. I connected with bci2000, by using bat file with actichamp source's executable. When clicking Set config, system log prompts failed to get device handle.I really could use your help,plesase.
Re: actichamp failed to get device handle
Hello hzong,
did you read the actiChamp's contribution page on the BCI2000 wiki?
https://www.bci2000.org/mediawiki/index ... :actiCHamp
The battery might be low, or actiCHampAmplifierID might be set to something other than 0.
Thanks a lot. At present, I have solved this problem by using RDAClient. Thanks again
Users browsing this forum: No registered users and 23 guests
