The error is BCI2000 link to neuroscan
When I use the latest version of BCI2000 to connect to scan4.5, BCI2000 has been stuck in the state of requesting connection. But when I use the 3.03 version of BCI2000, it can connect normally. Signal source module is NeuroscanClient, signal processing module is DummySignalProcessing, application module is FeedbackDemo.
Re: The error is BCI2000 link to neuroscan
what do you mean by "latest version"? A download from the BCI2000 website, or did you compile from source?
--Juergen
--Juergen
I've tried both. One download from BCI2000 wensite is BCI2000 Binary, another one download from SVN for compling.
Unfortunately, we don't have a Neuroscan amplifier nor the Scan4.3 software available to test.
We can do remote debugging, if you agree, using Google Remote Desktop. Let us know your location so we can pick a time that is convenient for both of us.
Sorry, it took so long to reply. I was anxious to carry out the experiment and used the old version of bci2000. I'm in China. You can choose a suitable time.
I'm in Germany. 19:00 your time tomorrow will fit me well.
Is it 19:00, August 11, 2021 Beijing time?
About three hours later?
Yes, that is what I suggested. But we may start now if it fits you.
Our Google Remote Desktop code is 1994 0502 7716.
What happened? Was the connection accidentally disconnected?
I accidentally pressed the "back" button in my browser, sorry.
On the Neuroscan site, I found a FAQ document (http://compumedicsneuroscan.com/wp-cont ... n-FAQs.pdf) that mentions Scan 4.5.1 hotfix 2 to be downloaded here:
https://www.dropbox.com/s/6kmhvrgd98qdv ... 2.exe?dl=0
Did you install Scan 4.5.1 hotfix 2? If not, does the problem persist after installing it?
I added a parameter RequestExtendedInformation which is off by default. So the issue should be solved for you.
Thank you for reporting.
After installing scan 4.5.1 hotfix 2, the problem still exists.
After updating bci2000, the problem is solved.
Thank you for your help.
Thanks for the information, and best regards,
Jürgen
Jürgen
Users browsing this forum: Google [Bot] and 23 guests
