BCI2000 v3.6 beta test
Posted: 08 Dec 2015, 16:02
Dear BCI2000 User Community,
we are soliciting beta users for the upcoming BCI2000 v3.6 release.
Please download the most recent beta binaries from the links below and report any issues, recommendations and suggestions in this thread.
Please note that this will require a BCI2000 user account.
* Sign up for a BCI2000 account: http://www.bci2000.org/GPL/
* Your forgot your BCI2000 account password: see instructions at the bottom of this post
BCI2000 v3.6 - binaries - release candidate R5711 - August 31th, 2017
Synopsis:
This is the sixth release candidate of BCI2000 v3.6 based on SVN revision 5711. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
For your convenience, please see the links below to the windows installers for the pre-compiled beta binaries. After installing you will find the following four folders in your destination directory:
BCI2000.x32: 32-bit version with dll files in prog folder
BCI2000.x64: 64-bit version with dll files in prog folder
BCI2000.x32.bundled: 32-bit version with executable and dll files bundled
BCI2000.x64.bundled: 64-bit version with executable and dll files bundled
Download BCI2000 (all contributions, without extensions):
Windows Installer (~600 MB):
http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5711.setup.exe
Download BCI2000 (all contributions, including selected extensions):
Windows Installer (~700 MB):
http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5711.setup.exe
Instructions on how to enable and use the selected BCI2000 extensions.
https://www.bci2000.org/mediawiki/index.php/Contributions:AudioExtension
https://www.bci2000.org/mediawiki/index.php/Contributions:EyetrackerLogger
https://www.bci2000.org/mediawiki/index.php/Contributions:EyetrackerLoggerTobii3
https://www.bci2000.org/mediawiki/index.php/Contributions:EyetrackerLoggerTobiiX
https://www.bci2000.org/mediawiki/index.php/Contributions:EyetrackerLoggerTobiiPro
https://www.bci2000.org/mediawiki/index.php/Contributions:GazeMonitorFilter
https://www.bci2000.org/mediawiki/index.php/Contributions:ParallelPortFilter
https://www.bci2000.org/mediawiki/index.php/Contributions:StimBoxFilter
Issues resolved
* Stability Improvements
* Grapevine Module Improvements
* Bugfix: SpatialFilter in CAR mode would have zero output rather than all channels when SpatialFilterCAROutput set to empty.
* Bugfix: gUSBampADC digital output preflight
* Bugfix: EyetrackerLoggerTobii3 output format now consistent with other eye-tracker loggers
New Features
* LiveAmpLiveAmpADC
* EyetrackerLoggerTobiiPro
Focus testing on
* Platform testing on Windows 7, 8, 10 for 32 and 64 bit for all 4 binary compilations
* Platform testing on 1, 2, 4, 6, 8 and 12 core CPUs.
* Deployment on Windows PCs with and without administrator privileges.
* Deployment on Windows PCs with Antivirus software installed.
* Functionality of BCI2000 extensions.
* Timing behavior
* Inspection of the audio output
* Inspection of the visual output
* Functionality in conjunction with acquisition hardware
* Functionality in conjunction with experimental paradigms
Known Issues:
* none
BCI2000 v3.6 - binaries - release candidate R5570 - October 20th, 2016
Synopsis:
This is the fifth release candidate of BCI2000 v3.6 based on SVN revision 5570. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5570.setup.exe
http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5570.setup.exe
Issues resolved
* Bundled Applications issue on Windows 10 fixed.
New Features
* none
Focus testing on
* Timing behavior
Known Issues:
* none
BCI2000 v3.6 - binaries - release candidate R5558 - October 5th, 2016
Synopsis:
This is the fourth release candidate of BCI2000 v3.6 based on SVN revision 5558. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~600 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5558.setup.exe.html
Windows Installer (~700 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5558.setup.exe.html
http://www.bci2000.org/wiki/index.php/Contributions:AudioExtension
http://www.bci2000.org/wiki/index.php/Contributions:EyetrackerLogger
http://www.bci2000.org/wiki/index.php/Contributions:EyetrackerLoggerTobii3
http://www.bci2000.org/wiki/index.php/Contributions:EyetrackerLoggerTobiiX
http://www.bci2000.org/wiki/index.php/Contributions:GazeMonitorFilter
http://www.bci2000.org/wiki/index.php/Contributions:ParallelPortFilter
http://www.bci2000.org/wiki/index.php/Contributions:StimBoxFilter
Issues resolved
* BrainProducts vAmp and ActiCHamp source modules are now more reliable.
* Wearable Sensing DSISerial source module is now updated to use the latest API (1.13.1) to provide better timing performance.
* Stability improvements.
* BCI2000 Shell scripting bug with "WAIT FOR" fixed.
* IIRFilter windowing bug fixed.
* Application is now more reliable.
* Audio output working on all sounds cards.
New Features
* Timing improvements to visual stimuli presentation. Visual stimuli are presented within one frame and actual presentation time is measured and stored in a state.
* Operator now uses Greek symbols (e.g., µ) for signal units.
* Binaries now show build version in their properties.
* BCI2000 applications are now grouped in the task bar.
* BCI2000 applications now use custom icons.
* Updated MEX files.
* Updated BCPy2000 framework.
Focus testing on
* Timing behavior
Known Issues:
* none
BCI2000 v3.6 - binaries - release candidate R5393 - June 8th, 2016
Synopsis:
This is the third release candidate of BCI2000 v3.6 based on SVN revision 5393. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~600 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5393.setup.exe.html
Windows Installer (~700 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5393.setup.exe.html
Issues resolved
* Watches are now working properly for stream states (e.g., digital inputs that are sampled with the source signal).
New Features
* none
Focus testing on
* Timing behavior
Known Issues:
* none
BCI2000 v3.6 - binaries - release candidate R5388 - June 2nd, 2016
Synopsis:
This is the second release candidate of BCI2000 v3.6 based on SVN revision 5388. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~600 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5388.setup.exe.html
Windows Installer (~700 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5388.setup.exe.html
Issues resolved
* minor performance improvements
New Features
* none
Focus testing on
* Timing behavior
Known Issues:
* none
BCI2000 v3.6 - binaries - release candidate R5380 - May 26th, 2016
Synopsis:
This is the first release candidate of BCI2000 v3.6 based on SVN revision 5380. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~600 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5380.setup.exe.html
Windows Installer (~700 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5380.setup.exe.html
Issues resolved
* bci_stream2mat now fully functional with new data files
* bug in storing digial inputs for g.HIamp resolved
* g.HIamp and g.USBamp now store digital inputs as individual states
* mex updated for all platforms (mexw64, mexw32, mexmaci64, mexmaca64)
New Features
* none
Focus testing on
* Timing behavior
Known Issues:
* none
BCI2000 v3.6 - binaries - beta version R5348 - May 9th, 2016
Synopsis:
This is the eight public beta of BCI2000 v3.6 based on SVN revision 5348, which focuses mainly on bug fixes. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~600 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5348.setup.exe.html
Windows Installer (~690 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5348.setup.exe.html
Issues resolved
* FilePlayback now working properly.
* Windows 10 issue fixed that was caused by 64-bit bundled binaries not starting.
* StimulusPresentation bug fixed that was caused by StimulusBegin state set incorrectly when stimulus was suppressed by EarlyOffsetExpression before being displayed.
* gNautilus bug fixed that was caused by bundled version not loading settings file properly.
* actiCHamp bug fixed that was caused by initialization issue.
* Offline filters bug fixed that was caused by new data format.
* Operator parameter writing bug fixed that was caused by invalid parameters.
* Operator crash fixed that was caused by occasional access violations in OperatorLib::StateMachine.
New Features
* BCPy2000 now bundled with v3.6 beta
Focus testing on
* Timing behavior
Known Issues:
- Missing 64-bit libraries for some contributed SignalSource modules
http://www.bci2000.org/tracproj/ticket/176
- MEX files not yet updated
BCI2000 v3.6 - binaries - beta version R5304 - March 28th, 2016
Synopsis:
This is the seventh public beta of BCI2000 v3.6 based on SVN revision 5304, which focuses mainly on bug fixes. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~560 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5304.setup.exe.html
Windows Installer (~630 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5304.setup.exe.html
Issues resolved
* Bug with closing all visualization windows that terminated Operator process if main window was hidden is now fixed.
- http://www.bci2000.org/tracproj/ticket/184
* Bug in g.MOBIlab+ auto config fixed
New Features
* Auto config for g.MOBIlab+
Focus testing on
* Platform testing on Windows XP, 7, 8, 10 for 32 and 64 bit for all 4 binary compilations
* Timing behavior
Known Issues:
- Newly compiled mem mex interface crashing
BCI2000 v3.6 - binaries - beta version R5296 - March 22th, 2016
Synopsis:
This is the sixth public beta of BCI2000 v3.6 based on SVN revision 5296, which focuses mainly on bug fixes and packaging. As part of the packaging we now provide installers to deploy BCI2000 on your PC. Two installers are provided, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g.tec stim box) to selectively test the functionality of these BCI2000 extensions.
Windows Installer (~560 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5296.setup.exe.html
Windows Installer (~630 MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5296.setup.exe.html
Issues resolved
* Bundled BCI2000 modules are now packaged with all necessary dynamic link libraries.
* Operator Watches are now able to detect transient changes in events and states, rather than only testing the first sample in each block.
* Operator now does not hang on shutdown if any Telnet connections is open.
* Events now propagate to source module.
- http://www.bci2000.org/tracproj/ticket/185
* MATLAB mex files are newly compiled for Windows x32 and x64 platforms using latest MATLAB SDK.
* g.MOBIlab+ issue with digital input expression is now fixed.
* Bug in BCI2000Remote fixed.
- http://www.bci2000.org/bbs/viewtopic.php?f=1&t=2877
New Features
* Executables, installers and dynamic link libraries are now digitally signed with SHA1/SHA256 certificates.
* Installer for installing/uninstalling BCI2000.
* Installer is whitelisted with Symantec.
* Auto config for g.MOBILlab, g.MOBIlab+ and g.STIMbox
Focus testing on
* Timing behavior
Known Issues:
- Closing all visualization windows will terminate Operator process if main window was hidden
BCI2000 v3.6 - binaries - beta version R5253 - February 22th, 2016
Synopsis:
This is the fifth public beta of BCI2000 v3.6 based on SVN revision 5253, which focuses mainly on bug fixes and new functionality for the g.HIamp source module. As usual, we provide two BCI2000 packages, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g-tec stim box) to selectively test the functionality of these BCI2000 extensions.
For your convenience, please see the links below to the pre-compiled beta binaries. These archives contain 4 binary compilations:
Self Extracting Archive (~400MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5253.exe.html
ZIP Archive (~800MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5253.zip.html
Self Extracting Archive (~450MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5253.exe.html
ZIP Archive (~900MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5253.zip.html
Issues resolved
* Fixed issues in EEGOSource (now supports EE213 amplifier)
* Fixed timing issues on dual core cpus
* Fixed deadlock on dual core cpus
* Fixed issue with ParallelPortFilter on systems that don't have a parallel port
* Fixed issue in MATLAB processing filter (ticket #183)
* Performance improvements in JoystickLogger
New Features
* g.HIamp now supports auto configuration
* g.HIamp now supports impedance measurement for passive and active electrodes
* g.HIamp now supports calibration mode
* g.HIamp now robust against data loss by using the hardware sample counter
* EEGOSource now provides default amplifier fragments
* Bundled BCI2000 version now provides more detailed error information if it fails to load the executable (relevant if using aggressive anti-virus software)
Focus testing on
* Antivirus Scanner behavior in conjunction with BCI2000
* Extensions testing
* Timing behavior
Known Issues:
- missing 64-bit libraries for some contributed SignalSource modules
BCI2000 v3.6 - binaries - beta version R5225 - January 30th, 2016
Synopsis:
This is the fourth public beta of BCI2000 v3.6 based on SVN revision 5225, which focuses mainly on performance improvements. In this fourth beta version, we provide two BCI2000 packages, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g-tec stim box) to selectively test the functionality of these BCI2000 extensions.
Self Extracting Archive (~400MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5225.exe.html
ZIP Archive (~800MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5225.zip.html
Self Extracting Archive (~450MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5225.exe.html
ZIP Archive (~900MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5225.zip.html
Issues resolved
* Fixed timing issues caused by waiting for tread activation.
* Fixed race condition in the OnSet() function.
* Fixed issues that prevented running the ParallelPortFilter on some machines.
* Fixed issue in Operator log that could slow down the system.
* Fixed remaining issue in Tiny::Thread() to make it more robust against improper thread termination on Win32 (could result in endless waiting on program exit).
* Fixed issue in audio output to eliminate a deadlock condition on program exit.
New Features
* none
Focus testing on
* Timing behavior
Known Issues:
- missing 64-bit libraries of contributed SignalSource modules
- timing behavior unreliable at high clock rates (i.e., SamplingRate / SampleBlockSize >= 20)
BCI2000 v3.6 - binaries - beta version R5207 - January 20th, 2016
Synopsis:
This is the third public beta of BCI2000 v3.6 based on SVN revision 5207. In this third beta version, we provide two BCI2000 packages, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g-tec stim box) to selectively test the functionality of these BCI2000 extensions.
Self Extracting Archive (~400MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5207.exe.html
ZIP Archive (~800MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5207.zip.html
Self Extracting Archive (~450MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5207.exe.html
ZIP Archive (~900MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5207.zip.html
Issues resolved
* Now compliant with Antivirus Scanners
-- http://www.bci2000.org/tracproj/ticket/182
* New implementation of the ParallelPortFilter with better performance and reliability
-- Split up into logger (source module) and filter (application) component
-- Hardware IO addresses are now obtained through Windows configuration manager, avoiding dangerous manual configuration
-- Accessing inpout32 driver device file directly, rather than through inpout32.dll (no deployment overhead)
-- Prompting user to download input32 driver installer from BCI2000 website if device file not present
-- http://www.bci2000.org/wiki/index.php/Contributions:ParallelPortFilter
* Improved performance and reliability of gUSBampSource
-- DigitalInputs are now stored in one state per amplifier, rather than one state per digital input bit.
* Improved Operator signal visualization
* Updated DSISerial based on v1.13.0 of DSI_API
-- Removed dependency on MSVC runtime redistributables
* Fixed issue from previous beta version that prevented loading certain BCI2000 files in MATLAB on the OSX platform.
* Fixed issue from previous beta version that prevented accessing/visualizing states that were written in the source module along with the signal (State::StreamKind).
* Fixed issue with TextField objects that prevented to completely conceal of the objects.
* Fixed issue in the Tiny::Thread() to make BCI2000 more robust against improper thread termination on Win32 (could result in endless waiting on program exit).
New Features
* New source module for ANT Neuro EEG amplifiers
-- http://www.bci2000.org/wiki/index.php/Contributions:EEGOSource
-- https://www.ant-neuro.com/products/eego_product_family
* Auto-configuration functionality for gUSBampSource which automatically detects and configures the connected amplifiers
* Added bit extractor functions to ArithmeticExpression: bit( value, position ), bits( value, position, count )
* P3SpellerTask modification to allow showing different icons on intensification. This can be used to show "Faces" on intensification of a row/column.
-- http://www.bci2000.org/wiki/index.php/User_Reference:P3SpellerTask#Visual_Representation
-- http://www.bci2000.org/wiki/index.php/User_Reference:P3SpellerTask#TargetDefinitions
Focus testing on
* Timing behavior
Known Issues:
BCI2000 v3.6 - binaries - beta version R5181 - December 21th, 2015
Synopsis:
This is the second public beta of BCI2000 v3.6 based on SVN revision 5181. In this second beta version, we provide two BCI2000 packages, one without and one with selected BCI2000 extensions. We kindly ask users with the appropriate hardware (i.e., sound card, Tobii T/X eye tracker, Tobii EyeX eye tracker, PCI-based parallel port, g-tec stim box) to selectively test the functionality of these BCI2000 extensions.
Self Extracting Archive (~400MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5181.exe.html
ZIP Archive (~800MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5181.zip.html
Self Extracting Archive (~450MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5181.exe.html
ZIP Archive (~900MB): http://bci2000.org/downloads/bin/BCI2000.x32.x64.extensions.beta.R5181.zip.html
Issues resolved
- BrainProducts vAmp now with 64-bit support
- Bundled applications now execute on Windows 10
http://www.bci2000.org/tracproj/ticket/180
- digital states written in source modules at high sampling rates now without any performance penalty
http://www.bci2000.org/tracproj/ticket/181
Focus testing on
* Timing behavior
Known Issues:
- Antivirus scanners flag BCI2000
BCI2000 v3.6 - source code - compile and debug instructions - December 10th, 2015
Synopsis:
This are the instructions for BCI2000 developers on how to build and debug your own binaries.
Pre-requisites:
* Windows 32 or 64 bit OS.
* TortoiseSVN (https://tortoisesvn.net/downloads.html) [make sure to check "command line tools" on installation]
* CMake 3.3.2 (https://cmake.org/files/v3.3/cmake-3.3.2-win32-x86.exe) [make sure to check "add to path for all users" on installation]
* Visual Studio 2012 Express (http://www.microsoft.com/en-us/download/details.aspx?id=34673)
* Visual Studio 2012 Update 4 (https://www.microsoft.com/en-us/download/details.aspx?id=39305)
Process:
* SVN check out the BCI2000 trunk (https://www.bci2000.org/svn/trunk) setting the revision to the one of the latest binary (see R-number in the binary section above).
* For 32-bit builds start "Make VS2012 Project Files.cmd" in the batch folder.
* For 64-bit builds start "Make VS2012 Win64 Project Files.cmd" in the batch folder.
* This cmd file will open a command window in which you can select which modules should be included in the build.
* To fine-tune (e.g., to disable the application bundling, USE_APPLICATION_BUNDES) open the "Configure.sh.cmd" to start the CMake GUI, check/uncheck the appropriate options and click at "Configure" and then "Generate" at the bottom left corner of this window.
* Open the "BCI2000.sln", select the "Release" or "Debug" and the select "Build Solution" from the "Build" menu.
* After building is completed, you can debug the "Debug" build by starting the appropriate BCI2000 configuration and selecting the corresponding BCI2000 module from "Attach to Process" from the Debug menu. Set appropriate breakpoints and perform your debugging.
BCI2000 v3.6 - binaries - beta version R5158 - December 8th, 2015
Synopsis:
This is the first public beta of BCI2000 v3.6 based on SVN revision 5158. For your convenience, please see the links below to the pre-compiled beta binaries. These archives contain 4 binary compilations:
Download Self Extracting Archive (~500MB):
http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5158.exe.html
Download ZIP Archive (~800MB):
http://bci2000.org/downloads/bin/BCI2000.x32.x64.beta.R5158.zip.html
New Features
* Build environment: Now based on Visual Studio 2012, CMake 3 and Qt 5.3.
* Platform support: Now with 32 and 64 bit build support for Windows platforms.
* Packaging: BCI2000 applications are now bundled together with necessary dll files into one binary.
* New acquisition hardware supported: g.tec g.Nautilus, Enobio 3G, Wearable Sensing Dry Sensor Interface, Blackrock, ANT Neuro eego, iotech analog digital boards
* New acquisition hardware features: g.tec (digital inputs, hold signal).
* New Peripheral Hardware Supported: gtec g.STIMbox, PCI-based ParallelPort, TobiiX, CyberGlove data glove
* New APIs Supported: PortAudio (audio), LibAV (video).
* Under the Hood Improvements: Timing markers to mark exact stimulus delivery time.
Focus testing on
* Timing behavior
Known Issues:
- digital states written in source modules at high sampling rates impose a performance penalty
- Bundled applications do not execute on Windows 10
BCI2000 - You forgot your BCI2000 SVN/BBS/Wiki account password?
Please contact bci2000@neurotechcenter.org and provide your BCI2000 username to initiate the password reset. You will receive a new password within 24 hours.
