Parameter file definition
xjwang
Post by xjwang » 09 Nov 2015, 04:58
Hi, there!
I'm new to the BCI2000 and planning on using the g.tec to do my project.
When I checked the details of the g.USBamp.prm, I found there were around 4 parameters after the variable name :shock: :shock: :shock: , like the following lines:
Source:Signal%20Properties:DataIOFilter int SourceCh= 8 16 1 % // number of digitized and stored channels
Source:Signal%20Properties:DataIOFilter int SampleBlockSize= 8 32 1 % // number of samples transmitted at a time
Source:Signal%20Properties:DataIOFilter int SamplingRate= 256 256Hz 1 % // sample rate
Source:Signal%20Properties:DataIOFilter list ChannelNames= 0 // list of channel names
Source:Signal%20Properties:DataIOFilter floatlist SourceChOffset= 8 0 0 0 0 0 0 0 0 0 % % // Offset for channels in A/D units
Source:Signal%20Properties:DataIOFilter floatlist SourceChGain= 8 0.019 0.019 0.019 0.019 0.019 0.019 0.019 0.019 0.003 % % // gain for each channel (A/D units -> muV)
Source:gUSBampADC intlist SourceChList= 0 0 1 128 // list of channels to digitize
Source:gUSBampADC intlist SourceChDevices= 1 8 16 1 17 // number of digitized channels per device
Source:gUSBampADC int NumBuffers= 2 1 2 32 // number of software buffers to use
Source:gUSBampADC string DeviceIDMaster= auto // deviceID for the device whose SYNC goes to the slaves
Source:gUSBampADC int FilterEnabled= 1 1 0 1 // Enable pass band filter (0=no, 1=yes)
Source:gUSBampADC float FilterHighPass= 0.1 0.1 0 50 // high pass filter for pass band
Source:gUSBampADC float FilterLowPass= 60 60 0 4000 // low pass filter for pass band
Source:gUSBampADC int FilterModelOrder= 8 8 1 12 // filter model order for pass band
Source:gUSBampADC int FilterType= 1 1 1 2 // filter type for pass band (1=BUTTERWORTH, 2=CHEBYSHEV)
Source:gUSBampADC int NotchEnabled= 1 1 0 1 // Enable notch (0=no, 1=yes)
Source:gUSBampADC float NotchHighPass= 58 58 0 70 // high pass filter for notch filter
Source:gUSBampADC float NotchLowPass= 62 62 0 4000 // low pass filter for notch filter
Source:gUSBampADC int NotchModelOrder= 4 4 1 10 // filter model order for notch filter
Source:gUSBampADC int NotchType= 1 1 1 2 // filter type for pass band (1=CHEBYSHEV, 2=BUTTERWORTH)
Source:gUSBampADC list DeviceIDs= 1 auto // list of USBamps to be used (or auto)
Source:gUSBampADC int DigitalInput= 0 0 0 1 // enable digital input:  0: false, 1: true (enumeration)
Source:gUSBampADC int DigitalOutput= 0 0 0 1 // enable digital output on block acquisition (boolean)
Source:gUSBampADC string DigitalOutputEx= % // expression for output on digital output 2 (expression)
Source:gUSBampADC int SignalType= 1 0 0 1 // numeric type of output signal:  0: int16, 1: float32 (enumeration)
Source:gUSBampADC int AcquisitionMode= 0 0 0 2 // data acquisition mode:  0: analog signal acquisition, 1: calibration, 2: impedance (enumeration)
Source:gUSBampADC int CommonGround= 1 0 0 1 // internally connect GNDs from all blocks:  0: false, 1: true (enumeration)
Source:gUSBampADC int CommonReference= 1 0 0 1 // internally connect Refs from all blocks:  0: false, 1: true (enumeration)
Source:Alignment:AlignmentFilter int AlignChannels= 0 0 0 1 // align channels in time (0=no, 1=yes)
Source:Alignment:AlignmentFilter floatlist SourceChTimeOffset= 0 0 % % // time offsets for all source channels (may be empty)
which I searched the WIKI and other resources but could find the proper definition.
There are some settings I could understand while some I really could not, so :( :( :(
Please help!
Re: Parameter file definition
Post by pbrunner » 07 Dec 2015, 14:12
Xjwang,
to answer your question, the for parameters for an int/float data type are:
8 16 1 %
       |--- max (if % then no max)
     |----- min (if % then no min)
   |------- default
|---------- value
Please note that you rarely have to edit the parameter files in a text editor. You can do this within the BCI2000 operator GUI, or if you want to automatically write parameters, you can use the convert_bciprm MEX interface within MATALB [1].
[1] http://www.bci2000.org/wiki/index.php/U ... ert_bciprm
