BCI in C++ builder XE2
Tjehani
Post by Tjehani » 18 Nov 2011, 16:42
Dear BCI200 programmers , I would like to know how to compile the BCI in C++ builder XE2
thanks in advance
Tjehani
Re: BCI in C++ builder XE2
Post by Tjehani » 19 Nov 2011, 07:02
please I need help , where are the programmers
Post by mellinger » 21 Nov 2011, 07:14
Use the C++ Builder IDE to open the *.bpg files provided in the src/ and src/contrib/ directories. These files point to BCB6 project files, which your IDE will then update to match its own version.
Tjehani
Post by Tjehani » 21 Nov 2011, 11:40
do you mean It is okay if I open the BCI2000.bpg by the C++ Builder XE2 ?
becaues when I do that i got a lot of linker error
brcc32 command line for "gUSBampgetinfo.vrc"
c:\program files (x86)\embarcadero\rad studio\9.0\bin\cgrc.exe -c65001 gUSBampgetinfo.vrc -fogUSBampgetinfo.res
ilink32 command line
c:\program files (x86)\embarcadero\rad studio\9.0\bin\ilink32.exe -Lobj;"c:\program files (x86)\embarcadero\rad studio\9.0\lib\debug";.;
..\..\..\..\extlib\gtec\gUSBamp;"c:\program files (x86)\embarcadero\rad studio\9.0\lib";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\obj";
"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";.;
"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files
(x86)\embarcadero\rad studio\9.0\lib\win32\release";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\win32\release\psdk";"C:\Program Files
(x86)\FastReports\LibD16";"c:\program files (x86)\embarcadero\rad studio\9.0\RaveReports\Lib";"C:\Program Files (x86)\Raize\CS5\Lib\RS-XE2\Win32";
"C:\Users\Public\Documents\RAD Studio\9.0\DCP" -jobj;"c:\program files (x86)\embarcadero\rad studio\9.0\lib\debug";.;..\..\..\..\extlib\gtec\gUSBamp;
"c:\program files (x86)\embarcadero\rad studio\9.0\lib";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\obj";"c:\program files
(x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";.;..\..\..\..\extlib\gtec\gUSBamp;"c:\program
files (x86)\embarcadero\rad studio\9.0\lib";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\obj";"c:\program files (x86)\embarcadero\rad
studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad
studio\9.0\lib\win32\release";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\win32\release\psdk";"C:\Program Files (x86)\FastReports\LibD16";
"C:\Users\Public\Documents\RAD Studio\9.0\DCP" -Iobj -l..\..\..\..\..\prog -v -Gn -G8 -Tpe c0x32 obj\gUSBampgetinfo.obj ,
..\..\..\..\..\prog\gUSBampgetinfo.exe , ..\..\..\..\..\prog\gUSBampgetinfo.map , import32.lib cw32.lib , , gUSBampgetinfo.res gUSBampgetinfo.res
[ILINK32 Error] Error: Unresolved external 'GT_GetSerial' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_OpenDevice' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_GetNumberOfFilter' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_GetFilterSpec' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_GetNumberOfNotch' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_GetNotchSpec' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unresolved external 'GT_CloseDevice' referenced from C:\BCI2000\SRC\CORE\SIGNALSOURCE\G.USBAMP\GETINFO\OBJ\GUSBAMPGETINFO.OBJ
[ILINK32 Error] Error: Unable to perform link
Failed
what makes those error appear ???
Tjehani
Post by Tjehani » 22 Nov 2011, 07:37
please I need help
Post by mellinger » 22 Nov 2011, 08:23
Please note that tests with all supported compilers are only performed for source code revisions corresponding to binary releases, which are listed at:
http://www.bci2000.org/wiki/index.php/B ... on_History
If you cannot compile BCI2000 with a certain compiler, it is advisable to go back to the source code revision corresponding to the latest binary release, or to a revision that has "XYZ compilation" in its commit message, whichever is newest.
In response to your posts, I fixed C++ Builder compilation, so you should be able to compile revision 3664.
Tjehani
Post by Tjehani » 22 Nov 2011, 10:00
I do all the step to compile the BCI2000 , but I got linker error
what I did are
1- download the code using svn client in certain directory in c
2- then I go to C:\BCI200\src\contrib and I open the file BCI2000_All.pbg using C++Builder XE2 After that , I press build All then I got a lot of errors
please install the XE2 builder and try to run the BCI2000 I need help it is urgent
ahalharbi
Post by ahalharbi » 22 Nov 2011, 14:45
I have same problems ...
plz any Helllllpppp
Post by mellinger » 22 Nov 2011, 14:59
I fixed the code on SVN such that BCI2000_All compiles without errors when using C++ Builder 2010. Please update your source code, remove all .cbproj and .cbproj.local files, and try compilation again. If it doesn't work, please be more specific about the errors that occur.
arwa_cs
Post by arwa_cs » 22 Nov 2011, 15:16
Thanks for your help ,but this what we do,but still the same problem
Tjehani
Post by Tjehani » 22 Nov 2011, 16:15
Dear , I would like to tell that I used windows 7 as OS , and I use c++ Builder XE2 , I update the code
then I run it then I got the Following :
Checking project dependencies...
Compiling SWApp.cbproj (Debug, Win32)
bcc32 command line for "Presentation\Views\Win32\GUIScoreView.cpp"
c:\program files (x86)\embarcadero\rad studio\9.0\bin\bcc32.exe -D_DEBUG;NO_STRICT;BCI2000;PERUVIAN_BRIGHTNESS_HACK;MODTYPE=3;NO_APP_WINDOW;;
NO_STRICT;BCI2000;PERUVIAN_BRIGHTNESS_HACK;MODTYPE=3;NO_APP_WINDOW; -nobj -I..\..\..\shared\gui;..\..\..\shared\modules\application\gui;
..\..\..\shared\modules\application\audio;..\..\..\shared\modules\application\utils;..\..\..\shared\fileio;..\..\..\shared\config;
..\..\..\shared\utils\Expression;..\..\..\shared\utils;..\..\..\shared\types;..\..\..\shared\modules;..\..\..\shared\bcistream;
..\..\..\shared\accessors;..\..\..\shared;..;Presentation;Presentation\Models;Presentation\Utils;Presentation\Utils\Win32;Presentation\Utils\BCI2000;
Presentation\Views;Presentation\Views\Win32;"c:\program files (x86)\embarcadero\rad studio\9.0\include";"c:\program files (x86)\embarcadero\rad
studio\9.0\include\vcl";..\..\..\Application\shared\audio;"c:\program files (x86)\embarcadero\rad studio\9.0\include\dinkumware";"c:\program files
(x86)\embarcadero\rad studio\9.0\include\windows\vcl";..\..\..\shared\fileio;..\..\..\shared\utils\Expression;..\..\..\shared\types;
Presentation\Views;..\..\..\shared\modules;Presentation\Models;..\..\..\shared\gui;..\..\..\shared\bcistream;Presentation\Views\Win32;
..\..\..\shared\modules\application\gui;Presentation;Presentation\Utils;Presentation\Utils\BCI2000;..\..\..\shared\accessors;..\..\..\shared\utils;
..\..\..\shared\modules\application\utils;..\..\..\shared\modules\application\audio;"C:\Program Files (x86)\Embarcadero\RAD
Studio\9.0\include\boost_1_39\boost\tr1\tr1";"C:\Program Files (x86)\Embarcadero\RAD Studio\9.0\include\boost_1_39";"c:\program files
(x86)\embarcadero\rad studio\9.0\include";"c:\program files (x86)\embarcadero\rad studio\9.0\include\dinkumware";"c:\program files
(x86)\embarcadero\rad studio\9.0\include\windows\crtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\sdk";"c:\program files
(x86)\embarcadero\rad studio\9.0\include\windows\rtl";"c:\program files (x86)\embarcadero\rad studio\9.0\include\windows\vcl";"C:\Program Files
(x86)\FastReports\LibD16";"c:\program files (x86)\embarcadero\rad studio\9.0\RaveReports\Lib";"C:\Program Files (x86)\Raize\CS5\Lib\RS-XE2\Win32" -y
-c -tM -tW -Hc -C8 -oobj\GUIScoreView.obj -Od -v -vi- -H=Debug_Build\SWApp.pch -H -tWM -5 -Vx -r- -k -Ve Presentation\Views\Win32\GUIScoreView.cpp
[BCC32 Warning] W8123 Path 'c:\program files (x86)\embarcadero\rad studio\9.0\include\vcl' not found - path ignored in option '-I'
[BCC32 Error] GUIScoreView.cpp(98): E2357 Reference initialized with 'TRect', needs lvalue of type 'TRect'
[BCC32 Error] GUIScoreView.cpp(98): E2342 Type mismatch in parameter 'inTRect' (wanted 'TRect &', got 'TRect')
[BCC32 Error] GUIScoreView.cpp(108): E2357 Reference initialized with 'TRect', needs lvalue of type 'TRect'
[BCC32 Error] GUIScoreView.cpp(108): E2342 Type mismatch in parameter 'inTRect' (wanted 'TRect &', got 'TRect')
[BCC32 Error] GUIScoreView.cpp(134): E2357 Reference initialized with 'TRect', needs lvalue of type 'TRect'
[BCC32 Error] GUIScoreView.cpp(134): E2342 Type mismatch in parameter 'inTRect' (wanted 'TRect &', got 'TRect')
Failed
Elapsed time: 00:00:00.8
Please Download the c++ builder XE2 and run the BCI , it does not work
Post by mellinger » 23 Nov 2011, 07:34
Thanks for posting the error message. I fixed that one.
Are there more compilation errors?
Tjehani
Post by Tjehani » 23 Nov 2011, 10:25
I am working now on revision 3668 (I don't know which revision you update ??) please answer
I did All the previous steps
and then click run
Then I got this BCI200 ERRoR:
" SignalSource : could not connect to operator module "
by the way I copy the operator.exe and the operator.dll to the prog in BCI2000 foldrer
but it does not work !!
another compilation error :
[BCC32 Error] Task.cpp(701): E2357 Reference initialized with 'std::vector<float,std::allocator<float> >', needs lvalue of type 'std::vector<float,std::allocator<float> >'
Tjehani
Post by Tjehani » 23 Nov 2011, 11:30
Another Compilation Error :
brcc32 command line for "FieldTripBuffer.vrc"
c:\program files (x86)\embarcadero\rad studio\9.0\bin\cgrc.exe -c65001 "FieldTripBuffer.vrc" -foFieldTripBuffer.res
..\..\..\shared\fileio;..\..\..\shared\utils\Expression;..\..\..\shared\utils;..\..\..\shared\modules;..\..\..\shared\types;..\..\..\shared\bcistream;
..\..\..\shared\modules\signalprocessing;..\..\..\extlib\fieldtrip\buffer\src;..\..\..\shared\accessors;..\..\..\extlib\fieldtrip\buffer\src;
"..\..\..\extlib\fieldtrip\pthreads-win32\lib";..\..\..\shared\modules\signalprocessing;..\..\..\shared\utils\Expression;..\..\..\shared\utils;
..\..\..\shared\types;..\..\..\shared\modules;..\..\..\shared\fileio;..\..\..\shared\bcistream;..\..\..\shared\accessors;..;"c:\program files
studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";..\..\..\shared\fileio;..\..\..\shared\utils\Expression;
..\..\..\shared\utils;..\..\..\shared\modules;..\..\..\shared\types;..\..\..\shared\bcistream;..\..\..\shared\modules\signalprocessing;
..\..\..\extlib\fieldtrip\buffer\src;..\..\..\shared\accessors;..\..\..\extlib\fieldtrip\buffer\src;"..\..\..\extlib\fieldtrip\pthreads-win32\lib";
..\..\..\shared\modules\signalprocessing;..\..\..\shared\utils\Expression;..\..\..\shared\utils;..\..\..\shared\types;..\..\..\shared\modules;
..\..\..\shared\fileio;..\..\..\shared\bcistream;..\..\..\shared\accessors;..;"c:\program files (x86)\embarcadero\rad studio\9.0\lib";"c:\program
files (x86)\embarcadero\rad studio\9.0\lib\obj";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad
studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\win32\release";"c:\program files (x86)\embarcadero\rad
studio\9.0\lib\win32\release\psdk";"C:\Program Files (x86)\FastReports\LibD16";"c:\program files (x86)\embarcadero\rad studio\9.0\RaveReports\Lib";
"C:\Program Files (x86)\Raize\CS5\Lib\RS-XE2\Win32";"C:\Users\Public\Documents\RAD Studio\9.0\DCP" -jobj;"c:\program files (x86)\embarcadero\rad
studio\9.0\lib\debug";..\..\..\shared\fileio;..\..\..\shared\utils\Expression;..\..\..\shared\utils;..\..\..\shared\modules;..\..\..\shared\types;
..\..\..\shared\bcistream;..\..\..\shared\modules\signalprocessing;..\..\..\extlib\fieldtrip\buffer\src;..\..\..\shared\accessors;
..\..\..\extlib\fieldtrip\buffer\src;"..\..\..\extlib\fieldtrip\pthreads-win32\lib";..\..\..\shared\modules\signalprocessing;
..\..\..\shared\utils\Expression;..\..\..\shared\utils;..\..\..\shared\types;..\..\..\shared\modules;..\..\..\shared\fileio;..\..\..\shared\bcistream;
..\..\..\shared\accessors;..;"c:\program files (x86)\embarcadero\rad studio\9.0\lib";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\obj";
"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";"c:\program files (x86)\embarcadero\rad studio\9.0\lib\psdk";..\..\..\shared\fileio;
"C:\Users\Public\Documents\RAD Studio\9.0\DCP" -Iobj -l..\..\..\..\prog -v -Gn -aa -V5.0 -G8 -Tpe c0w32 memmgr.lib sysinit.obj
obj\FieldTripBuffer.obj obj\FieldTripBufferFilter.obj obj\PipeDefinition.obj obj\cleanup.obj obj\clientrequest.obj obj\dmarequest.obj
obj\endianutil.obj obj\extern.obj obj\printstruct.obj obj\tcprequest.obj obj\tcpserver.obj obj\tcpsocket.obj obj\util.obj obj\BCIEvent.obj
obj\Environment.obj obj\ParamRef.obj obj\BCIError.obj obj\BCIError_module.obj obj\BCIException.obj obj\BCIDirectory.obj obj\CoreModule.obj
obj\CoreModuleVCL.obj obj\GenericFilter.obj obj\MessageHandler.obj obj\MessageQueue.obj obj\ExpressionFilter.obj obj\Brackets.obj obj\CfgID.obj
obj\Color.obj obj\EncodedString.obj obj\GenericSignal.obj obj\GenericVisualization.obj obj\HierarchicalLabel.obj obj\Label.obj obj\LabelIndex.obj
obj\Param.obj obj\ParamList.obj obj\PhysicalUnit.obj obj\SignalProperties.obj obj\SignalType.obj obj\State.obj obj\StateList.obj obj\StateVector.obj
obj\StateVectorSample.obj obj\Status.obj obj\SysCommand.obj obj\VisID.obj obj\ClassName.obj obj\EventQueue.obj obj\ExceptionCatcher.obj
obj\ArithmeticExpression.obj obj\Expression.obj obj\ExpressionParser.obj obj\MeasurementUnits.obj obj\OSError.obj obj\OSEvent.obj obj\OSMutex.obj
obj\OSThread.obj obj\PrecisionTime.obj obj\SockStream.obj obj\VersionInfo.obj , ..\..\..\..\prog\FieldTripBuffer.exe ,
..\..\..\..\prog\FieldTripBuffer.map , rtl.lib vcl.lib vclx.lib import32.lib cp32mt.lib , , FieldTripBuffer.res
[ILINK32 Error] Error: Unresolved external '_pthread_mutex_lock' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\UTIL.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_mutex_unlock' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\UTIL.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_cond_broadcast' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\DMAREQUEST.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_attr_destroy' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\FIELDTRIPBUFFERFILTER.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_attr_init' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\FIELDTRIPBUFFERFILTER.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_attr_setdetachstate' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\FIELDTRIPBUFFERFILTER.OBJ
[ILINK32 Error] Error: Unresolved external '_ptw32_push_cleanup' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSERVER.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_testcancel' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSERVER.OBJ
[ILINK32 Error] Error: Unresolved external '_ptw32_pop_cleanup' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSOCKET.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_exit' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSOCKET.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_create' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSERVER.OBJ
[ILINK32 Error] Error: Unresolved external '_pthread_detach' referenced from C:\USERS\TOSHIBA\DESKTOP\MASTER\MASTER PROJECT\BC\SRC\CONTRIB\SIGNALPROCESSING\FIELDTRIPBUFFER\OBJ\TCPSERVER.OBJ
Failed
Post by mellinger » 23 Nov 2011, 12:02
In a version control system such as SVN, revisions correspond to code changes. Once a revision exists, it does not change. When code changes are committed into the version control system, a new revision is created that contains the changes.
Please see this thread for a possible solution:
http://www.bci2000.org/phpbb/viewtopic.php?f=1&t=1110
Users browsing this forum: Bing [Bot] and 2 guests
