User Reference:NullFileWriter
The NullFileWriter component does not write brain signal data (Null File Format). Individual filters may still write log files to the directory defined by the DataDirectory, SubjectName, and SubjectSession parameters.
These are storage parameters common to all Data File Formats.
DataDirectory
SubjectName
A textual ID for the subject. This text will appear in session directories, and data file names.
SubjectSession
A textual ID for the current session. Sessions correspond to data directories. The path of a session directory is constructed according to
{DataDirectory}/{SubjectName}{SubjectSession}
SubjectRun
A number indicating the current run. Runs correspond to data files. To avoid accidental loss of data, run numbers are auto-incremented to the largest unused value. Within a session directory, data file names are constructed according to
{SubjectName}S{SubjectSession}R{SubjectRun}
A data file's extension depends on its File Format.
ID_System, ID_Amp, ID_Montage
NullFileWriter Specific Parameters
SavePrmFile
Specifies whether there should be a parameter file created for each run. This parameter is optional, and will not appear in the parameter configuration dialog by default. To use it, specify --SavePrmFile=1 on the command line when starting up the source module.
User Reference:DataIOFilter, User Reference:Data File Formats, Programming Reference:GenericFileWriter Class
