User Reference:IIRBandpass
Design an IIR filter consisting of up to three parts (high-pass, low-pass and notch) and apply it as part of the signal-processing chain. To use it as a bandpass, specify the desired lower end of the band as a high-pass corner, and the desired upper end of the band as a low-pass corner.
Jeremy Hill
HighPassCorner
High-pass cutoff frequency. The default is 0, which disables the high-pass.
HighPassOrder
Filter order for the high-pass. The default is 2. A value of 0 disables the high-pass.
LowPassCorner
Low-pass cutoff frequency. The default is 0, which disables the low-pass.
LowPassOrder
Filter order for the low-pass. The default is 4. A value of 0 disables the high-pass.
NotchCenter
Notch center frequency. The default is 0, which disables the notch filter.
NotchOrder
Filter order for the notch. The default is 4. A value of 0 disables the notch filter.
User Reference:Filters, Contributions:HilbertSignalProcessing
Namespaces
Variants
Actions
Navigation
Toolbox
