User Reference:EDFFileWriter
The EDFFileWriter component writes out data in the EDF File Format.
These are storage parameters common to all Data File Formats.
DataDirectory
SubjectName
A textual ID for the subject. This text will appear in session directories, and data file names.
SubjectSession
A textual ID for the current session. Sessions correspond to data directories. The path of a session directory is constructed according to
{DataDirectory}/{SubjectName}{SubjectSession}
SubjectRun
A number indicating the current run. Runs correspond to data files. To avoid accidental loss of data, run numbers are auto-incremented to the largest unused value. Within a session directory, data file names are constructed according to
{SubjectName}S{SubjectSession}R{SubjectRun}
A data file's extension depends on its File Format.
ID_System, ID_Amp, ID_Montage
SavePrmFile
Determines whether a BCI2000 parameter file is saved along with the EDF file. As EDF cannot represent BCI2000 parameters, parameter information is lost if SavePrmFile is switched off. This parameter is optional, and will not appear in the parameter configuration dialog by default. To use it, specify --SavePrmFile=1 on the command line when starting up the source module.
EDFFileWriter Specific Parameters
SubjectYearOfBirth
Year the subject was born, in YYYY format.
SubjectSex
An enumerated value specifying the subject's sex:
  • 0: not specified,
  • 1: male,
  • 2: female.
TransducerType
A string describing the transducer (sensor) type, e.g. EEG: Ag/AgCl.
SignalUnit
A string specifying the physical unit of the calibrated signal. Differently from the notation used throughout the rest of BCI2000, this is usually "uV" rather than "muV".
EquipmentID
A string identifying the equipment provider.
LabID
A string identifying the recording laboratory.
TechnicianID
A string identifying the recording technician.
User Reference:DataIOFilter, User Reference:Data File Formats
