User Reference:BCI2000FileWriter
The BCI2000FileWriter component writes out data in the native BCI2000 File Format.
These are storage parameters common to all Data File Formats.
DataDirectory
SubjectName
A textual ID for the subject. This text will appear in session directories, and data file names.
SubjectSession
A textual ID for the current session. Sessions correspond to data directories. The path of a session directory is constructed according to
{DataDirectory}/{SubjectName}{SubjectSession}
SubjectRun
A number indicating the current run. Runs correspond to data files. To avoid accidental loss of data, run numbers are auto-incremented to the largest unused value. Within a session directory, data file names are constructed according to
{SubjectName}S{SubjectSession}R{SubjectRun}
A data file's extension depends on its File Format.
ID_System, ID_Amp, ID_Montage
BCI2000FileWriter Specific Parameters
SavePrmFile
Specifies whether parameters are to be stored in a parameter file separate from the data file. The additional parameter file will be redundant, as native BCI2000 data files always contain the complete set of parameters. This parameter is optional, and will not appear in the parameter configuration dialog by default. To use it, specify --SavePrmFile=1 on the command line when starting up the source module.
StorageTime
At the beginning of the recording, this parameter's content is overwritten with a string describing the current date and time. Any user-specified value is ignored.
User Reference:DataIOFilter, User Reference:Data File Formats, Programming Reference:GenericFileWriter Class
