Template:StimulusTaskParams
WindowBackgroundColor
PreRunDuration
PostRunDuration
PreSequenceDuration
StimulusDuration
InterpretMode
- 0: no target is announced "attended", and no classification is performed;
- 1: online or free mode: classification is performed, but no "attended target" is defined;
- 2: copy mode: "attended" targets are defined, classification is performed.
DisplayResults
