Programming Reference:TextField Class
src/shared/gui
The TextField class represents a rectangle on a GraphDisplay that contains text.
TextField(GraphDisplay, int zOrder=MessageZOrder)
In the constructor, specify the target display, and optionally a z order value.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
string Text
The text to be displayed.
float TextHeight
The text height in units of text field height. Typically, this would be between 0.6 and 0.8.
RGBColor TextColor
The color used to draw text.
RGBColor Color
The text field's background color.
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum AspectRatioMode (rw)
One of the following options:
AdjustNone
No adjustment is made.
AdjustWidth
AdjustHeight
AdjustBoth
GUI::Rect DisplayRect (rw)
The bounding rectangle of the space that is occupied by the object. This is given in coordinates relative to the size of the object's GraphDisplay; there, the upper left corner corresponds to (0,0), the lower right corner to (1,1). When a GraphObject is created, its display rectangle is empty.
Programming Reference:GraphObject Class, Programming Reference:GraphDisplay Class, Programming Reference:TextStimulus Class
