Programming Reference:Shape Class
src/shared/gui/Shapes
The Shape class is a base class for geometric shapes, inheriting the GraphObject interface and adding its own interface for shape properties, and intersection testing.
Shape(GraphDisplay, int zOrder = ShapeZOrder)
The constructor takes the usual GraphDisplay reference argument, and an integer indicating the shape's z position.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
Methods for Intersection Testing
enum TestResult
Intersection test results have one of the following values:
- false_
- There is no intersection.
- true_
- There is an intersection.
- undetermined
- Intersection has not been determined.
TestResult Contains(Point)
Tests whether the specified point is part of the shape. Descendants of Shape should implement this function.
TestResult IntersectsArea(Shape)
Tests for intersection with a second shape's area.
New descendants of Shape should use RTTI to test whether the argument is an existing descendant class, and provide intersection testing for all existing Shape descendants. For arguments that are not of a known type, the function is supposed to return undetermined.
This way, it is ensured that there exists an IntersectsArea() implementation for all pairs of Shape descendants, without modifying existing classes when creating new ones.
static bool AreaIntersection(Shape, Shape)
Tests for intersection between the two shapes specified.
GUI::Point Center
The shape's center of mass, i.e. what would be considered its "position". For simple shapes, this coincides with the center of the shape's bounding rectangle.
float LineWidth
The shape border's line width, in pixels.
RGBColor FillColor
The shape's filling color.
RGBColor Color
The color of the shape's border.
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum AspectRatioMode (rw)
One of the following options:
- AdjustNone
- No adjustment is made.
- AdjustWidth
- The object's width is adapted to its contents, while keeping its height constant.
- AdjustHeight
- The object's height is adapted to its contents, keeping its width constant.
- AdjustBoth
- Both the object's height and width are adjusted to its content.
GUI::Rect DisplayRect (rw)
The bounding rectangle of the space that is occupied by the object. This is given in coordinates relative to the size of the object's GraphDisplay; there, the upper left corner corresponds to (0,0), the lower right corner to (1,1). When a GraphObject is created, its display rectangle is empty.
Events
OnPaint(GUI::DrawContext)
This is where the actual shape is drawn. Descendants of Shape must provide their own implementation of the OnPaint event handler.
Programming Reference:GraphObject Class, Programming Reference:GraphDisplay Class
Programming Reference:RectangularShape Class, Programming Reference:EllipticShape Class
