Programming Reference:RectangularShape Class
src/shared/gui/Shapes
The RectangularShape class represents a rectangle drawn onto a GraphDisplay. Typically, it is used to represent a 2D feedback cursor or target.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
GUI::Point Center
The shape's center of mass, i.e. what would be considered its "position". For simple shapes, this coincides with the center of the shape's bounding rectangle.
float LineWidth
The shape border's line width, in pixels.
RGBColor FillColor
The shape's filling color.
RGBColor Color
The color of the shape's border.
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum AspectRatioMode (rw)
One of the following options:
AdjustNone
No adjustment is made.
AdjustWidth
AdjustHeight
AdjustBoth
GUI::Rect DisplayRect (rw)
The bounding rectangle of the space that is occupied by the object. This is given in coordinates relative to the size of the object's GraphDisplay; there, the upper left corner corresponds to (0,0), the lower right corner to (1,1). When a GraphObject is created, its display rectangle is empty.
Programming Reference:Shape Class, Programming Reference:GraphObject Class, Programming Reference:GraphDisplay Class
