Programming Reference:ImageStimulus Class
The ImageStimulus class provides a VisualStimulus that displays an image loaded from a file.
string File (rw)
A relative or absolute path to an image file. When relative, the path is interpreted relative to the application module's working directory at startup.
enum RenderingMode (rw)
One of GUI::RenderingMode::Transparent or GUI::RenderingMode::Opaque. When Transparent, the image's bottom leftmost pixel is taken to represent its background, and pixels of this color are not drawn, allowing objects below the ImageStimulus to appear.
Inherited from VisualStimulus
enum PresentationMode (rw)
This property determines the way a stimulus is presented. It is one of the following:
ShowHide
The stimulus is initially invisible, and visible while being presented.
Intensify
During presentation, the contrast of the stimulus is increased.
Grayscale
During presentation, the stimulus is displayed in grayscale rather than color.
Invert
During presentation, the stimulus appears color-inverted.
Dim
During presentation, the contrast of the stimulus is reduced.
float DimFactor (rw)
Determines the contrast ratio between presentation and non-presentation in Dim and Intensify modes. In Intensify mode, values greater 1 will result in a brighter appearance during presentation; in Dim mode, values greater 1 will result in a darker appearance during presentation. Due to saturation effects, the result may not be as expected.
Inherited from GraphObject
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum AspectRatioMode (rw)
One of the following options:
AdjustNone
No adjustment is made.
AdjustWidth
AdjustHeight
AdjustBoth
GUI::Rect DisplayRect (rw)
The bounding rectangle of the space that is occupied by the object. This is given in coordinates relative to the size of the object's GraphDisplay; there, the upper left corner corresponds to (0,0), the lower right corner to (1,1). When a GraphObject is created, its display rectangle is empty.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
Programming Reference:VisualStimulus Class, Programming Reference:GraphObject Class
