Programming Reference:GraphObject Class
src/shared/gui
The GraphObject class defines an interface for graphical objects displayed by a BCI2000 application. GraphObjects are tied to a GraphDisplay, which typically represents an application window.
GraphObjects possess a z-order position that determines how they are drawn on top of each other. You do not instantiate GraphObjects directly; rather, you create objects of classes that inherit the GraphObject interface.
The GraphObject class is contained within the GUI namespace. To use it, either qualify its name: GUI::GraphObject (recommended for header files); or put a using statement on top of the file (recommended for cpp files):
using namespace GUI;
GraphObject(GraphDisplay, int zOrder)
The constructor of a graph object requires a reference to a GraphDisplay, and an integer that specifies the object's z order, where lower values correspond to objects that are drawn on top of objects with larger z order values.
Show()
Hide()
Makes the object invisible.
Invalidate()
Paint()
Change()
bool Click(GUI::Point)
GraphDisplay Display (r)
bool Visible (r)
float ZOrder (rw)
enum AspectRatioMode (rw)
One of the following options:
- AdjustNone
- No adjustment is made.
- AdjustWidth
- The object's width is adapted to its contents, while keeping its height constant.
- AdjustHeight
- The object's height is adapted to its contents, keeping its width constant.
- AdjustBoth
- Both the object's height and width are adjusted to its content.
GUI::Rect DisplayRect (rw)
The bounding rectangle of the space that is occupied by the object. This is given in coordinates relative to the size of the object's GraphDisplay; there, the upper left corner corresponds to (0,0), the lower right corner to (1,1). When a GraphObject is created, its display rectangle is empty.
Events
OnPaint(GUI::DrawContext)
From its OnPaint event handler, a GraphObject renders itself into a device context and rectangle specified in its DrawContext argument. The DrawContext consists of an OS device context handle, and a rectangle in device coordinates. Implementing this function is mandatory for classes inheriting from GraphObject.
OnChange(GUI::DrawContext)
The OnChange event handler is called to notify the object that a change in size, position, or output device has occurred. E.g., if the object maintains an internal bitmap buffer that it uses to speed up paint operations, it should delete and re-create that buffer from its OnChange handler to ensure consistency with the output draw context. Objects that render themselves directly do not need to override the (empty) default handler.
bool OnClick(GUI::Point)
The OnClick event handler receives a point in normalized coordinates, and returns whether it considers itself clicked. The default handler does nothing, and returns true.
Descendants
The GraphObject class is parent to the following class hierarchy:
GraphObject |-> Shape |-> RectangularShape | |-> EllipticShape |-> StatusBar |-> ImageStimulus |-> TextField |-> Scene
