Contributions:NIDAQ-MX
National Instruments is one of the most widespread vendors of Data Acquisition boards, and also of the software LABVIEW used in many laboratories. Thus, data acquisition boards from NI are common in many systems and can be used as EEG source under BCI2000.
The NI_DAQ_MX component implements the source code for the configuration and the control of NI boards using the NIDAQ MX driver version 8.5 or later. The driver also supports some of the traditional NIDAQ (legacy) boards, please refer to the official NI documentation for the complete list of supported boards (NI DAQMX 8.5 readme).
http://www.bci2000.org/svn/trunk/src/contrib/SignalSource/NIDAQ-MX
Giulio Pasquariello, Gaetano Gargiulo
(c) 2008 DIET Biomedical unit
University of Naples "Federico II"
- V1.00 - 02/01/2008 - First start and first functioning BETA version
- V1.05 - 07/01/2008 - Added documentation of each function
- Known to compile under: 1750 (BCI2000 v1.41 tag)
The diffusion of NI board in measurement laboratories created the need for support of newest devices in BCI2000. This document describes this support that consists a BCI2000-compatible Source Module (NIDAQmx.exe). This module is described below and has been tested with DAQPad 6015 USB.
NIDAQmx Source Module
The BCI2000-compatible Source Module NIDAQmx.exe can be used instead of any other source module. In addition to standard parameters (i.e. SampleBlockSize, SamplingRate, SourceCh), this BETA driver is limited to acquire 16 channels and the terminal configuration is fixed to "Not Referenced Single Ended" on a bipolar range of ± 5V. These settings may be changed at compilation time, and all the config instructions are placed in the ADConfig() function. Please refer to your hardware manual for supported settings.
BoardNumber
The NI-ADC board's device number.
Notes on recompiling
Include the nidaqmx.lib file in the project. This library file has already been converted from OMF to COFF using the omf2coff DOS utility contained in the Borland C Builder directory and is included in the ZIP file; the original NIDAQmx library is also included, and has been renamed to NIDAQmx_orig.lib.
