Contributions:GenerateCalibration
[edit]
GenerateCalibration is a GUI application that determines amplifier calibration parameters from a recorded data file.
[edit]
http://www.bci2000.org/svn/tags/BCI2000.v2.1/src/contrib/Tools/GenerateCalibration
[edit]
[edit]
Gerwin Schalk, Wadsworth Center, NYSDOH.
[edit]
- Initial development: 96
- Tested under: 412
- Known to compile under: 1528
[edit]
The Calibgen program takes as input a BCI2000 data file containing a calibration signal. The user selects the desired channels. The output is a BCI2000 parameter file fragment. Click on the SelectInput button and the next window appears. Next select the output file. Then click on go.
The selected file name will contain a BCI2000 parameter file fragment similar to the following:
Filtering floatlist SourceChOffset= 5 245 -202 -86 -155 17 0 -500 500 // offset for channels in A/D units Filtering floatlist SourceChGain= 5 0.00802 0.00806 0.00797 0.00805 0.00807 0.033 -500 500 // gain for each channel
This file can now be read into BCI2000 with the Load Parameters option.
[edit]
