BCI2000 Glossary
A glossary of terms specific to BCI2000.
Control Signal
The output of the signal processing module. When the Normalizer Filter is used, this signal has zero mean and unit variance.
Core Module
One of Data Acquisition, Signal Processing, and User Application Module. These are called core modules because they are involved in on-line processing, as opposed to the Operator Module, which controls operation, and passively displays data sent by core modules, but is not actively involved in processing.
Filter
A software component that is part of the BCI2000 processing pipe, or filter chain. Once per sample block, filters are called to act on data in a sequential fashion. A filter maintains its own parameters, and enables the user to configure its behavior from the operator module.
Module
A single executable that may act as Operator Module or one of the Core Modules.
Operator Module
The experimenter's user interface, from which the system is configured, started, and stopped.
Parameter
A system-wide setting that is constant during a run. Parameters may be of varying type (numeric, string, etc.) and shape (single-valued, list, matrix).
Roundtrip
The time needed for a sample block to traverse the core modules. To fulfil the real-time constraint, roundtrip time may not exceed the physical duration of a sample block.
Run
The time period corresponding to a single data file. A run comprises a number of trials. From the user's view, a run starts when the operator's Start button is clicked, and ends when operation is suspended, either by the application module, or by a click on the Suspend button.
Sample Block
BCI2000 processes data in chunks, which are called Sample Blocks, or Data Blocks. Sample block size is configured through the SampleBlockSize parameter; often, ADC hardware imposes restrictions on sample block size.
The physical duration of a sample block is the inverse of the screen update rate, and determined by the ratio of sampling rate to sample block size.
Session
A number of runs of the same participant, recorded in sequence. Files from a session are recorded into a single data directory.
Source Signal
The signal that is acquired from hardware by the ADC filter, and recorded into the data file. The TransmissionFilter reduces the source signal to a user-defined subset of channels to reduce processing load in the on-line system.
State
A system-wide variable similar to what in other data acquisition applications is often called "event marker." State variables reflect important events during real-time system operation, and are saved to the data file along with each sample.
State Vector
A data structure that contains all states concatenated into a single bit string. The state vector is transmitted between modules once for each sample block, but a copy is saved with each sample of data.
Task
In a wider sense, the subject's task in a feedback experiment. In BCI2000, a piece of software that implements feedback (or, more generally, stimulus presentation) to the subject. In a BCI2000 application module, the task-defining software element is termed a "task filter".
Trial
In a cursor feedback paradigm, the time period during which the user moves the cursor. In an ERP paradigm, the time period following a single stimulus presentation.
Visualization
A core module may send information into a display window maintained by the operator module. Visualization data may be of type text, signal, or graphic.
